Dutch gable
I have drawn a dutch gable roof inside a parapet with a corner cut off as it is on a street corner/ intersection.
I used roof tools( gable) and then edited manually.
I chopped out unwanted roof so it is all inside parapet and healed lines and used sandbox to heal surface which filled with roof again.
My question is:
Will this filter through to takeoff.
Hi Jeffery,
We want to help you the best we can, Could you please attach a few screen captures of your model in regards to what you are talking about and I will be able to answer your question in detail.
Hi
Here is the image
https://lh3.googleusercontent.com/Z5bUgoAjxnzg9jBOxLZyOfC70hOA1cRZH5a7TaeKjQ=s192-p-no
Hi Jeffery,
Yes this will come out correctly in the Take-Off. Thank-you for sending a screen capture :slight_smile:
All that you chopped out will be removed from the take-off aswell. Using the sandbox was a good idea.
thanks
Thats fine :slight_smile:
