Drop to wall - other side of internal wall
Using the component tool i am trying to drop a ‘cupboard’ component to an internal wall.
My problem is it is on the wrong side of the internal wall, and I cant figure out how to put it on the correct side. Following the ‘principle of least surprise’ I tried using the arrow keys which modulate other component creation procedures such as walls, but that didn’t seem to do anything in this case.
How do I drop a component to a specific side of an internal wall ?
J
You actually had it correct. To switch the side of the Drop to Wall function you must use the ‘Right-Arrow’ Key on your keyboard.
You will notice that there is an orange line at the bottom of the wall when Dropping to a wall. When you tap the ‘Right-Arrow’ the orange line will swap sides.
I have created a video on doing this. Go to the link below -
youtu.be/YGgZLraANYo
This doesn’t work on my computer, which is not surprising given the other problems i have
Are you running a Windows or MAC operating system?
Have you updated to the latest version of PlusSpec?
Could you please send a screen captured video to my email - dean@rubysketch.com
This will give myself the best idea to tackle the problem.
Hi Dean,
I am using a Macbook pro. the same one that has the problems of PlusSpec causing Sketchup to hang if i ever edit a window or door.
2.4 GHz Intel Core i7
16GB Ram
AMD Radeon HD 6770M 1024 MB
MAC, OSX 10.11.2 (El Capitan),
Sketchup Pro 2016. 16.0.19913
PlusSpec v16.1.0-stage-dec
I have emailed you a link to a video
