hi guys,
got this problem with the doors.
The doors are not the correct size for the width of the walls. wall width is 90mm finish to finish the doors are generating at 130mm inside architrave to inside architrave.
thanks
hi guys,
thanks
I also changed the wall timber from 90 down to 70 prior to fitting off the door. but I also have a problem with doors where I haven’t changed the timber size.
Hi Myles,
What I would recommend to do is to go to the ‘Manual Overrides’ section of the Wall Tool and check that the ‘Cavity’ field is set to 0. This will normally happen when using the ‘Create Similar Wall’ option when you right click on a wall as it takes all values from the original wall to create the next wall.
