How can we easily add mullions to the glazed doors to achieve the ‘French Door’ look? The door icon looks like what I’d like to achieve :door-options-tool:
Also I had an issue with the Pivot Door last time I used it. The frame, etc was correct but the actual door itself was had set itself like a cavity slider back from it’s required position.
I ended up not using the door anyway due to the design. I haven’t needed to use it again so haven’t trailed it.
Cheers matt
