Swinging doors I have inserted into my model are not showing a swing outline at the bottom of the door. Therefore I cannot activate them to switch handing of the doors if required. The activation to open and close them is ok. Any ideas why this has happened.
Hi pitstruc,
It sounds like the door swing plans are hidden or turned off in your current view. To turn them on make sure the ‘Floor Plan A’ layer is turned on in your Layer Manager and they should appear. Also, if you’ve created scenes then it may just be the scene that you’re in that has the door swing plans turned off.
If you have not changed the scenes it will definitely be in the floor plan Scene, If you want to double check or are not sure, the best thing to do is to save the model as another name and then re click the scene generator :scene-gen:
remember to save your model as another name first.
