Hi there,
When placing doors into walls the door jamb is aligning within the stud frame. Is there a way to insert doors so that door jamb is inside of door opening in stud frame?
Hi there,
When you draw your wall, you have the option to set a stud frame opening or “frame buffer” You can also change these after you have drawn a wall by selecting the wall (or walls) and editing.
Here is how to set your frame-opening buffer
I also noticed you are using 240x45 LVL for wall frames, and the wall frame is none structural (It does not have a head over)? If you want a lintel over your frame, l, and you want to add load-bearing studs, you should choose the structural wall by clicking the drop-down next to “load-bearing wall” (above step 2) in the image above.
What are you designing with such large frames, Brendan?
