Can anyone point me in the right direction, when I add dimensions to either my model or lay out, it all gets messy with a lot of criss crossing lines. Is there a plug in to help or a efficient way to do this.
Hi Terry,
When adding dimensions to layout if you triple click on the dimension a node will appear at the end of a line and will allow you to drag the node up and down. By dragging the node closer to the dimension you will notice that the model now looks more neat with no lines crossing.
Hopefully this is what you were after and helps you.
Test this and let me know how you go and if anymore questions similar post here
Kind regards
