I have a vignette I want to use to create the slab with footings, walls, and roof system.
Unlike in the plus spec tutorials, once I right click on the my vignette wall, I don’t have the option to create a similar wall?
Not sure what I am missing?
Hi user86,
The “create similar wall” option will only appear if the right selection criteria is met (i.e. it’s a valid wall drawn using the
Wall Tool).
Here are some possibilities for why the option isn’t appearing for you. Are any of these the case for the issue you’re having?
I assume it’s inside a group or component? If so double click to open the container, then right click and create similar.
or explode the parent component or group.
