Not that I am aware of Morton, we spent years figuring it out.
Before you create your component, make sure it’s aligned to the drawing axes and connected to other geometry in the way you intend to use the component. This tip is especially important if you want the component to have a gluing plane or a cutting plane, because this context ensures that the component sticks to the plane or cuts a face in the way you expect. For example, make sure a couch’s legs are on the horizontal plane. Unless you need a window or a door in the floor, create a window or door component on a wall that’s vertically aligned to the blue axis. [size=1]forpc jiofi.local.html[/size]
