Hi guys
Is there a way or is there where an automatic colour code is created for different material, eg green for wet board with out constantly using the paint tool?
Hi guys
Trev you can take a screen shot of any color and then add it as a material eg Green wet area board, we used to do what you are asking for and also add n sheet sizes but architects and interior designers did not like it. Am I reading your question correctly? I think this video will help youtu.be/oVmvwpDIv8M If you want to add-in the join for say a 4’ sheet or 1200 simply screen shot a rectangle that is scale and then use the material in “create material” in the wall tool. I usually do 10 materials at a time you can do 1 in less than 30 seconds once you get used to it and you will have it forever.
