Close cavity at end of double brick wall
I understand that the trim end of wall function works with gyprock and skirting. But is there a way to do this with the brickwork aswell? We do a lot of concrete cavity filled brickwalls and looking to be able to identify where I need the cavities closed out.
I am also adding the concrete cavity as a separate wall to be able to estimate the qty of concrete required? Would an option be possible to add this to the wall construction?
any help much appreciated
To represent/draw the walls so they show correctly in plans and elevations I sugets the following
  1. draw the main corner walls individually using the double brick wall type
  2. Change the wall type to single masonry and draw the wing wall with a closed cavity
  3. To estimate the core fill on the dbl brick wall, I would assign a recipe to the internal side of the wall to quantify the concrete. For the single masonry wall, I would create a rectangular prism and associate a material using the custom estimation tool
Thanks Andrew. Appreciate the quick response
