Bonjour a vous, Je debute avec Plusspec et je rencontre deja un probleme. Comment faire pour creer des cloisons separative de 7cm ou 10 cm au norme francais.
Definitely I need assistance with the internal walls creation.
For example : I created an internal wall with a 13mm (Gyprock CD Plasterboard) on both sides (French internal walls), choose a color (all the set up are fine) and when I submit, nothing is happening. That is bothering me these past 2 days. Can you tell me if you have a set up for the internal walls that i can use or a tutorial or a webminary for that matter.
Merci
