Hello,
I’m new to this and will probably have many questions ![]()
- Can u change the direction of a sliding window as you can a door swing? I am using the double slider window and it has the fixed window on the outside edge and sliding in the middle, I want sliders from outside going in.
- I have an old mishmash house with part double brick, part single skin with engaged piers with stud infill and part stud with external cladding downstairs. How would you tackle this? I started to draw all dble brick then split parts and unlocked them and moved them to suit but it wasn’t working too well and walls wouldn’t join properly at corners
Thanks Sam
