Can't seem to set 24" o.c for interior only walls
PlusSpec Version: PlusSpec 23.3 (Rbz 23.3.0)
SketchUp Version: SketchUp 23
Computer Type: PC Windows 11
Profession: Builder
Issue/Concern:
This one’s pretty weird. I can set almost any stud spacing and can draw a wall. But if I choose 24" o.c, the Wall tool just refuses to draw a wall with that spacing. After fiddling around with it a bit. I found that I have to edit the wall to a bigger or smaller spacing (edit wall). Then, if I edit it again and set the spacing at 23 16/16", then the wall redraws with the 24" o.c spacing. It’s kind of frustrating.
I have PlusSpec 24.0
Thanks, Keith
Hi team,
I’m having a similarly-strange issue with setting slab heights. It seems that it’s very hit/miss on if the tool will apply a new thickness. It seems that once it gets “stuck” on a particular thickness, you have to mess with the depth for quite a while, making it bigger/smaller until finally you trick it into applying the new thickness.
Thanks, Keith
