Latest beta release: 4th November 2013. To be notified of new releases, subscribe to this topic.
Latest version can be downloaded here. Before updating, you should deleteC:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/rubysketch/ and C:/Program Files (x86)/Google/ Google SketchUp 8/Plugins/rubysketch/
Only releases from 8th August 2013 onwards are listed.
Release Notes:
8th August 2013[list]
[*] Add: Wall move Tool :push-pull-walls:
Add: Opening Redefine Tool :-opening-redefine-tool:
[list]
[*] First click to select opening
Click again to select anchors
Click two points to define the delta vector (how to move)
Press [kbd]DEL[/kbd] once the window is selected to remove it
[/:m]
[] Update: New Icons[/:m]
[] Update: Push-Pull walls now has 3 modes
By default joining walls will be modified to remain connected
Press [kbd]CTRL[/kbd] to swap to additive mode (joining walls will be added)
In additive mode, press [kbd]Insert[/kbd] to swap to strict additive mode (joining walls will be added even if parallel)
[/:m]
[] Update: Pressing [kbd]Enter[/kbd] will now end the current wall segment. Press [kbd]CTRL[/kbd] + [kbd]Enter[/kbd] to close the loop[/:m]
[] Update: Angle is now shown in slab and roof tools[/*:m][/list:u]
Add: “Select Adjacent Walls” option on right-click
Add: “Face from walls” options on right-click
Add: Pressing [kbd]CTRL[/kbd] while moving a window will produce a copy
Update: On tools that display an angle, you can specify the angle using Xd,L. For example 45d,1200mm will produce a 1.2m “line” at 45degrees to the X-Axis
Update: Pressing [kbd]UP[/kbd] while using wall-redefine tool ( :redefine-wall: ) will lock movement on the Z-Axis
Update: Added more materials
Update: Push-pull walls ( :push-pull-walls: ) is now in additive mode by default. Press [kbd]CTRL[/kbd] to return to modify mode
Fix: Inference locking no longer leaks between tools
Fix: Redefine-opening ( :-opening-redefine-tool: ) should be more lenient when accepting input.
Add: Test “one time” fields for layer options in :wall-tool: The value used will only be saved/overwritten if put in the uppermost input box
Update: Settings for :floor-joist-tool: are now remembered
Update: Settings for :floor-joist-tool: can now be changed after generation
Update: When moving only the top of an opening using :-opening-redefine-tool: , the overall height is no longer maintained. Instead the opening will be stretched, much like when moving the sides
Update: Changed the order of the tools
Fix: Fixed a crash experienced by some users when using :-opening-redefine-tool:
Warning: When updating to this version, you must uninstall previous versions.
To uninstall:
SketchUp 8
From C:\Program Files (x86)\Google\Google Sketchup 8\Plugins delete rubysketch.rb and the folder rubysketch
SketchUp 2013
From C:\Program Files (x86)\Sketchup\Sketchup 2013\Plugins delete rubysketch.rb and the folder rubysketch
All Versions
Press [kbd]windows key[/kbd] + [kbd]r[/kbd], type %APPDATA%\rubysketch in the dialog that appears and press OK.
[list][]If a folder appears, delete the following (if each exists) ponumber.txt and the folders .loadpath, loadpaths and plusspec
[/:m]
[*]Press [kbd]windows key[/kbd] + [kbd]r[/kbd], type %LOCALAPPDATA%\rubysketch in the dialog that appears and press OK.
[/*:m][/list:u]
Patch Notes:
Add: Stair Tool ( :stair-tool: )
Add: Scene Generator ( :scene-gen: ) [replaces template]
Add: Grid Tool ( :grid-tool: )
Add: BIM Tool ( :bim-tool: )
Update: Material and Component sort order is more logical
Update: Removed opening remove tool ( :opening-remove: ). To remove openings, hold control when using :-opening-redefine-tool:
Update: Textures are now more file-space efficient
Update: Old post tool removed
Update: New Icons
Update: Grouped Similar tools to make toolbar more manageable
Update: Automatic layering should be more flexible and appropriate
Update: Takeoff Template
Fix: Takeoff failures
Fix: Rounding Errors in takeoff and DC display
Fix: Layer references when selecting no material
Fix: Various other internal and minor changes et al.
