Hello,
I know there are corner windows in the components but is there a simple way to create a bay window?
thanks,
Joe
Hello,
thanks,
Joe
Hi Joe, thanks for your suggestion. You can add anything in PlusSpec as you are working in Sketchup, you can associate information with it & save the component for next time . I get it though you want to do it as quickly as everything else. We are happy to add in Bay Windows, can you let us know which manufacturers you are using? We can get in contact and add them and give teh functionality to add bays just like any other window. Our goal is to make PlusSpec faster to design with, estimate with and build with, your feedback is well received.
To get you up and going in the interim here are the steps to follow
If the window has a nib wall under you can simply draw a wall under.
Something you may not know you can, also split a wall 4 times and select the midle wall then push “CTRL” pull the wall and the 2 adjoining walls will splay ( you may want to add some guides)
