I am installing a window from a supplier that allows for a window height of 1200mm with 3 divisions horizontally ie two top panes are awning windows and the bottom in a fixed window. Is there some way i can have this happen when installing a window into a wall?
Hi ahdims,
I would recommend using the ‘Custom Window’ in the Window Tool as you can enter the number of horizontal & vertical panes of the window and then draw the window opening plans for the awning windows using the Line Tool in SketchUp.
