Is take off just good enough to give an estimate or actually generate an accurate cut to size / assembly / item list?
So I generate a framing plan with plusspec, take off the components. Size is important but so are labels. How do I get to number each component and then auto label in layout? For instance.
So, one can:
- Generate a plan in layout with component labels / part no etc. Do not want to do this manually.
- Generate a take off with associated components / sizes / labels etc
- Cut to Size using take off
- Label each component
- Look at the layout with all components labelled
- Assemble the frame based on the labels
I would like to have it so that if you have 5 joists the same size:
You can group them together and output like this:
J5 - J10 3400 or
J5 3400
Bearers would have different labels such as B1 and alike.
