Did you know you can associate a cost to Plant hire using the BIM tool? I usually add the hourly rate and the minimum hire in the quantity section.
- select a group or components inside Sketchup
- Click the BIM tool
or right-click the object and fill in the details you require in your estimate - Add the quantity of hour you require the Plant for
- Add the hourly rate
- To check you got it correct: Right-click the object and use the +Takeoff selection only, and search for the name in the search box inside the BOQ
