I would typically move and adjust walls (70mm internal) by the push pull tool, or move. What is the right way in PlusSpec. I have tried to extend the wall then right click and use join selected walls with no luck. When I right click and use the push pull command the entire wall moves,
Hi Terry,
There is a reason that the project and join tool won’t be working for you. The way your using PlusSpec to move walls is correct and the best way to use PlusSpec but the reason project and join won’t work corectly for you could be because the origin of the axis of the two walls aren’t correct. Check the images below.
